You are here: PSPad forum > English discussion forum > Re: Verilog.INI file
Posted by: G | Date: 2005-10-03 13:03 | IP: IP Logged
Whenever I try to enable this syntax highlighting, I get a PSPad application error... how do I correctly enable the verilog syntax highlighting once I have unzipped the verilog.INI file to the Syntax directory??
Thanks,
G
Posted by: pspad | Date: 2005-10-03 13:13 | IP: IP Logged
1. possible problem with your antivirus. Solution: exclude *.ini from your
antivirus resident shield
2. you havn't rights to write into PSPad directory. Solution: log as
admin, go to PSPad settings/System and check [x]multiuser environment
Posted by: Francesco | Date: 2010-03-03 16:19 | IP: IP Logged
Hi Sergey
please can you send me the verilog.ini ?
Best regards
Posted by: pspad | Date: 2010-03-03 16:51 | IP: IP Logged
Verilog is part of full PSpad installtion. Download full package from PSpad web page
Posted by: wtjanaka | Date: 2013-07-28 22:10 | IP: IP Logged
There is a small bug in the included Verilog.ini.
The KeyWordChars parameter should be:
KeyWordChars=`_$
instead of
KeyWordChars=`$
Otherwise, it will highlight variables like input_togo,
and double clicking on a word will not select the whole
word.
Posted by: pspad | Date: 2013-07-29 04:47 | IP: IP Logged
Thank you for info. I will modifi verilog.ini
