You are here: PSPad forum > English discussion forum > PHP compile 5.0 new version
#1 PHP compile 5.0 new version
Posted by: carrasco422 | Date: 2018-07-02 20:15 | IP: IP Logged
Using php-win.exe as compiler is freezing the application.
Had to change to 4.6 version back.
#2 Re: PHP compile 5.0 new version
Posted by: pspad | Date: 2018-07-02 20:49 | IP: IP Logged
Without compiler settings I can't answer. You didn't write any details
#3 Re: PHP compile 5.0 new version
Posted by: carrasco422 | Date: 2018-07-05 05:50 | IP: IP Logged
PHP 5.2.5.5 with php-gtk
#4 Re: PHP compile 5.0 new version
Posted by: pspad | Date: 2018-07-05 12:47 | IP: IP Logged
I need to know you compiler settings in PSPad.
#5 Re: PHP compile 5.0 new version
Posted by: carrasco422 | Date: 2018-07-08 02:35 | IP: IP Logged
Its default. Just added php-win. exe as compiler and the parameters pointin to php main file thats iniciates de GTX::main function. Same way with older pspad versions.
It starts running ok, even retrieven data from sql server, but suddenly freezes.
#6 Re: PHP compile 5.0 new version
Posted by: carrasco422 | Date: 2018-07-08 02:43 | IP: IP Logged
I'm using 4.5.9 now, but I did a new test with portable version 5.0 now, and the issue happen exactly in "GTK::main" function that starts the script loop.
Older versions runs fine.
#7 Re: PHP compile 5.0 new version
Posted by: pspad | Date: 2018-07-08 14:32 | IP: IP Logged
Version 5 has new option "Compile on the background"
Try to change this settings
#8 Re: PHP compile 5.0 new version
Posted by: carrasco422 | Date: 2018-07-11 09:47 | IP: IP Logged
Nothing changed. Still freezing.
#9 Re: PHP compile 5.0 new version
Posted by: pspad | Date: 2018-07-11 09:49 | IP: IP Logged
Can you send me some example what will cause freezing?
#10 Re: PHP compile 5.0 new version
Posted by: pspad | Date: 2018-07-11 10:02 | IP: IP Logged
In case if there is a cycle without end, PHP will never ends and PSpad will wait for it.
