You are here: PSPad forum > English discussion forum > ASCII character table vs ALT+num keys do not match
#1 ASCII character table vs ALT+num keys do not match
Posted by: clanman | Date: 2017-12-13 03:32 | IP: IP Logged
When using Alt+number to enter special characters, characters from 127 and above do not match what what is shown in he ASCII table.
Example
ASCII 167 is used for §.
Typed alt+167 gives º
Alt+167 copied from ASCII table gives §
On Format menu ANSI is selected
PSPad version is 4.6.2 (2750)
Is there a way to correct this?
Edited 1 time(s). Last edit at 2017-12-13 03:34 by clanman.
#2 Re: ASCII character table vs ALT+num keys do not match
Posted by: pspad | Date: 2017-12-13 05:51 | IP: IP Logged
It depends of regional settings - code page for non unicode programs in your system,
It depends of your keyboard settings. If you switch keyboard, the resul will be different.
#3 Re: ASCII character table vs ALT+num keys do not match
Posted by: clanman | Date: 2017-12-14 04:46 | IP: IP Logged
Regional settings are English (Australia)
Location is Australia
Keyboard and Languages -> Text Services and Input Languages settings are:
General Tab
Default input language is English (Australia) - US
Installed services are English (Australia) and English (United Sates) in that order
Administrative tab
Language for non-unicode programs is English (Australia)
Codepage is 850 - Multilingual
I changed from US to AUS ans still have the same problems.
Does PSPad look for the character or the ASCII code?
Are you able to advise what is used to obtain the required character §?
Edited 1 time(s). Last edit at 2017-12-14 04:55 by clanman.
#4 Re: ASCII character table vs ALT+num keys do not match
Posted by: pspad | Date: 2017-12-14 07:01 | IP: IP Logged
DoubleClick on the char in Ascii chart.
In unicode Windows you need to use unicode char code. Write please 0167 instead of 167 with ALT. I don't know why, you need to ask MS about it.
#5 Re: ASCII character table vs ALT+num keys do not match
Posted by: clanman | Date: 2017-12-14 21:37 | IP: IP Logged
Using 0167 and not 167 did it. Thanks Jan smiling smiley
