You are here: PSPad forum > English discussion forum > make clickcable link
Posted by: maximux007 | Date: 2017-11-07 22:09 | IP: IP Logged
Hi guys
forgive my English
and I hope to explain myself in the best possible way
use for a short time pspad and I have to say that it is extraordinary
Is there an option to make links clickable when I open a txt file containing a series of html addresses?
for example if I have a txt file containing the following internet address' www.pspad.com' and when opening the file I would like to click on the link to open it directly with my browser
It is possible this?
I mean to open it directly
click and open ?
thanks
regards
Posted by: pspad | Date: 2017-11-07 23:01 | IP: IP Logged
PSPad does it automatically. In plain text file link should be highlighted.
If not, open Program settings / Editor 2 and check Highlight URL address if no highlighter
If you want to open link in default application, use Ctrl+Click
Posted by: maximux007 | Date: 2017-11-08 17:34 | IP: IP Logged
thank you very much for your reply
What a sad thing the lack of this option
If you have time, please add it
regards
Posted by: maximux007 | Date: 2017-11-08 17:38 | IP: IP Logged
sorry but I had read badly
I understood that pspad didn't have this option
I also add that in my case (I tried to set up as you recommended me) it does not work automatically
Posted by: pspad | Date: 2017-11-08 17:38 | IP: IP Logged
Pspaf has this functionality. I explained it to you how it works. I can't add what is present. Highlight of links works automatically. Everything you need to do is keep CTRL when you click on any highlighted link.
Edited 1 time(s). Last edit at 2017-11-08 17:40 by pspad.
