You are here: PSPad forum > English discussion forum > Copy issue
Copy issue
#1 Copy issue
Posted by: maki | Date: 2017-10-30 10:20 | IP: IP Logged
The application has many imperfections or hinders the work.
Always put the text in PSPad at the beginning of the line when try to copy. Do not place anywhere.
Similar to other Emeditor text editor. How to set it in PSPad?
#2 Re: Copy issue
Posted by: pspad | Date: 2017-10-30 10:39 | IP: IP Logged
Program settings / Editor 1
Enable scroll past EOL and switch off trim trailing spaces
#3 Re: Copy issue
Posted by: maki | Date: 2017-10-30 11:19 | IP: IP Logged
These are my default settings so these settings will not work for me.
#4 Re: Copy issue
Posted by: pspad | Date: 2017-10-30 12:21 | IP: IP Logged
maki:
OK, In this case you are able to click anywhere on the empty line even behind the line end and paste text there.
#5 Re: Copy issue
Posted by: maki | Date: 2017-10-30 14:19 | IP: IP Logged
It always copies badly, leaving large blank spaces.
Or the text is completely misplaced.
#6 Re: Copy issue
Posted by: pspad | Date: 2017-10-30 15:32 | IP: IP Logged
maki:
Do you mean you copy text from the begin of line with no spaces before first line, place it anywhere and it put whitespaces before?
I don't know what do you wan to do.
If you want to put whole text moved to the right, use column mode Copy/Paste
#7 Re: Copy issue
Posted by: maki | Date: 2017-10-30 15:56 | IP: IP Logged
I just want to copy any text into the application window.
I have never had a problem with this in another text editor, so I do not know what's going on here.
Do not need multiple windows. I want to copy in the simplest way, normal and standard way every text to the application and I do not want to see any white space. I remember having always had this problem in practically every PSPad version, so I abandoned it for EmEditor, which seems to be more intuitive and the best possible.
Even the 64-bit version of PSPad still does not performance run text scrolling with long lines compared to the super-performance scrolling technology in EmEditor.
You can copy but I always have to set the cursor at the beginning.
The Emeditor is better, you do not have to do such things, everything automatically sets the start of the line and I like it very much.
Edited 2 time(s). Last edit at 2017-10-30 15:58 by maki.
