You are here: PSPad forum > English discussion forum > Bug? Select Matching Brackets Ctrl+Shift+M
Posted by: joemarfice | Date: 2017-09-08 14:32 | IP: IP Logged
Given this text:
a{b
c}d
If you press Ctrl+Shift+M (select everything between matching brackets), you will get the following selections, depending on where your cursor is when you press the key combo:
After 'a': whole {..} section (correct behavior)
Before 'b': whole {..} section (correct behavior)
After 'c': whole {..} section (correct behavior)
Before 'd': just the "()" (incorrect behavior!)
I am using PSPad v4.60 / 2700.
