You are here: PSPad forum > English discussion forum > Add user-defined highlighter based on built-in language
#1 Add user-defined highlighter based on built-in language
Posted by: human | Date: 2017-03-30 11:46 | IP: IP Logged
Is there any option to add some preprocessor symbols to PSPad for built-in languages like COBOL? I'd like to keep everything but only add some non-standard parts like "%mymacro(myparam, myparam)" or :mymacro param param2. Highlighting "%mymacro( )" or ":mymacro" would help to recognize it faster and it helps to directly see if it is written correctly.
Having the option to include some of these in the code explorer (for example ":" in column 7 starting a special section without the section keyword) would be nice, too.
Edited 1 time(s). Last edit at 2017-03-30 11:54 by human.
#2 Re: Add user-defined highlighter based on built-in language
Posted by: pspad | Date: 2017-03-30 12:16 | IP: IP Logged
No, cause current highlighters are hardcoded.
When version 5 will be stable, I will change editor engine and this one has user configurable highlighters. Then you will be able to add your own language parts.
#3 Re: Add user-defined highlighter based on built-in language
Posted by: human | Date: 2017-03-30 12:57 | IP: IP Logged
Thank you for the information, I'll wait for the new engine in 6.0
