You are here: PSPad forum > English discussion forum > Idea: Text diff - Both windows into new file - Delimiter
#1 Idea: Text diff - Both windows into new file - Delimiter
Posted by: Stefan | Date: 2017-03-29 11:13 | IP: IP Logged
Suggestion for
[Text diff]
tbResults_Caption=Results processing
mDiffOneFile_Caption=Both windows into new file
How I am able to remove
the lines from second document
at the end of the lines after I am finished?
Left file lines | Lines from right file
At the moment we can utilize RegEx Search&Replace
Search: (.+)\s+\|.+
Replace: $1
But I think the pipe symbol could be present in original test also:
Left | file| lines | Lines from right file
Idea, could there be a setting
to insert a user defined sign instead.
Settings > Program settings... > Text difference > Delimiter sign: [|       ]
Settings > Program settings... > Text difference > Delimiter sign: [Diff:   ]
Settings > Program settings... > Text difference > Delimiter sign: [###     ]
Settings > Program settings... > Text difference > Delimiter sign: [---     ]
Settings > Program settings... > Text difference > Delimiter sign: [-:-:-   ]
