You are here: PSPad forum > English discussion forum > Merge text in a txt file
Posted by: Esgrimidor | Date: 2017-03-09 14:02 | IP: IP Logged
Sometimes when copy/pasting a pdf file the resulting text is splitted from the original
How can I merge the resulting text according to the periods in the text. (Reconstructing phrases)
For example:
a
s
u
n
t
o
especial en cada caso.
Toda
vía
existen muchas opciones
y cada una de ellas más simple.
En todo caso es posible hacerlo.
Cada
caso
es
un
caso
aparte.
The final result may be :
asunto especial en cada caso.
Todavía existen muchas opciones y cada una de ellas más simple.
Cada caso es un caso aparte.
Best Regards
Nice program indeed
Posted by: vbr | Date: 2017-03-09 15:12 | IP: IP Logged
Hi, for such reconstruction, you can partly use "join lines", i.e. replace linebreaks with spaces
Edit: Lines manipulation: Join lines
Howewer, you will have to edit the text manually afterwards to delete the spaces between characters of some words and also insert linebreaks as needed.
hth,
Posted by: Esgrimidor | Date: 2017-03-10 13:28 | IP: IP Logged
I tried join lines manually
This was the result :
a s u n t o especial en cada caso.
Toda vía existen muchas opciones y cada una de ellas más simple.
In the word a s u n t o how can I convert to asunto ?
Best Regards
Nice program indeed
Posted by: Stefan | Date: 2017-03-10 13:31 | IP: IP Logged
Esgrimidor:In the word a s u n t o how can I convert to asunto ?
Move the cursor to the wanted space, then press the DEL key.
Move on with every space you want to remove.
No one else can know which space to remove and which not.
Posted by: Esgrimidor | Date: 2017-03-11 18:40 | IP: IP Logged
Nice to recognize you in the forum. I am contro as you know in the other.
Thanks a lot for your answer.
Best Regards.
Nice program indeed
