You are here: PSPad forum > English discussion forum > Deleting lines with string
#1 Deleting lines with string
Posted by: ssissons | Date: 2017-03-02 15:33 | IP: IP Logged
Is there a way to delete all lines in file, that contain a particular string? Without doing a Find w/List, and going through them manually? (It takes a lot of tedious effort to do this with large files.)
#2 Re: Deleting lines with string
Posted by: vbr | Date: 2017-03-02 17:19 | IP: IP Logged
ssissons:
you can use the [Copy] function of the Find dialog;
check [x] Copy non-matching
insert the specific string into the search field and press [Copy].
You effectively get a copy of the file excluding the lines containing the search word.
hth,
#3 Re: Deleting lines with string
Posted by: ssissons | Date: 2017-03-02 17:46 | IP: IP Logged
That worked great! Thank you very much!
