You are here: PSPad forum > English discussion forum > how can I include in PSPad plugin translator
Posted by: I like PSPad | Date: 2017-01-31 19:27 | IP: IP Logged
Hello Dear authors! Help me solve a problem how can I enable the plugin translator or do I need to download it? I want to edit files with PO is for them enigma2 I change the language so that I was clear! All images are just in different languages as well so I can edit on your tongue
Posted by: pspad | Date: 2017-01-31 20:31 | IP: IP Logged
Click on the third menu from the right and first subitem. Then double click on language you want
Posted by: I like PSPad | Date: 2017-01-31 21:32 | IP: IP Logged
You did not understand me I have to translate selected lines such as from English into German and tutzhe copy this translation have in notepade but I do not I would like to make use of your used
Posted by: pspad | Date: 2017-02-01 06:10 | IP: IP Logged
Sorry for misunderstanding.
PSPad has no translation tool included. But you can assign any external tool which supports command line.
You can assign command line tool in left favourite tab (general) or in highlighter settings (file type dependant)
You can integrate translation tool using PSPad scripting (menu Scripts)
Posted by: I like PSPad | Date: 2017-02-01 14:42 | IP: IP Logged
Thank you very much!!!
