You are here: PSPad forum > English discussion forum > Copied in status bar
Posted by: pythonui | Date: 2015-08-07 10:57 | IP: IP Logged
Can we have indicator in status bar for 'Copied'?
I mean when we copy some chars after then it will show status 'Copied'.
Posted by: pspad | Date: 2015-08-07 11:19 | IP: IP Logged
I don't see any useability. maybe you can explain it
Posted by: pythonui | Date: 2015-08-07 11:34 | IP: IP Logged
Yes..When we are going to copy something then we need to know is that copied or not?
Somtime it is possible that chars are not copied due to some reason so we can see in status bar for that.
It is upto you now !
Edited 1 time(s). Last edit at 2015-08-07 11:36 by pythonui.
Posted by: pspad | Date: 2015-08-07 11:44 | IP: IP Logged
It's up to other users if they will find it useful
Posted by: pythonui | Date: 2015-08-07 11:54 | IP: IP Logged
Yes...It is up to all users of this great editor !
Posted by: pythonui | Date: 2015-08-07 12:29 | IP: IP Logged
Hello Jan,
So you are going to put this in TODO ? :P
Posted by: pythonui | Date: 2015-08-13 09:21 | IP: IP Logged
Is there any chances for this feature?
Posted by: pspad | Date: 2015-08-13 09:29 | IP: IP Logged
pythonui:Is there any chances for this feature?
Get more users for your idea
Posted by: Andreas | Date: 2015-08-14 00:47 | IP: IP Logged
I remember in earlier versions that selected text sometimes is not copied after Ctrl-C. But I think this problem is gone with newer builds. And there is the "Clipboard Monitor window" (Alt-M) that already does what you want.
Posted by: pythonui | Date: 2015-08-17 06:11 | IP: IP Logged
Yes...Thanks for answer (Alt+M) .. But the need is just 'Copied' status in status bar..we do not need to show whole section for this....just a suggestion
