You are here: PSPad forum > English discussion forum > Problem with the highlighting of the brackets
Posted by: carolin | Date: 2014-11-12 15:41 | IP: IP Logged
Hi there ,
i have a problem with the brackets and couldn't find a solution though i googled the problem and tried some settings.
Normally, it is the presetting that a bracket is highlighted when you click it so you can see the bracket that closes it. This doesn't happen.
I have istalled pspad 4.5.8., and the function should normally be active.
If anyone has an idea for this problem that would be great!
Thank you.
Posted by: pspad | Date: 2014-11-12 16:45 | IP: IP Logged
Switch Wrap off (Ctrl+W)
Ensure, the bracket highlight is enabled in the Program settings / Editor 1:
Highlight matching brackets
Posted by: carolin | Date: 2014-11-13 11:36 | IP: IP Logged
Thank you very much! I don't know which concrete order it gives, but he shortkey was the solution.
Posted by: DavidB | Date: 2014-11-24 18:05 | IP: IP Logged
I use PsPad primarily for PHP files. I had it installed on my previous computer and it used to highlight parentheses, td's, divs, etc. so I could easily see if they were closed. I installed PsPad on my new Windows 8.1 computer and it is not highlighting anything.
Posted by: pspad | Date: 2014-11-24 18:49 | IP: IP Logged
Before you place new add, read previous answer please. I already answered in #2
Posted by: DavidB | Date: 2014-11-24 19:24 | IP: IP Logged
Sorry, I didn't initially think it was working but it DOES seem to work everywhere except in CSS. I can accept that it does not work in that one situation.
It is a great program.
Posted by: pspad | Date: 2014-11-24 19:29 | IP: IP Logged
Except CSS? There is no change in CSS.
