You are here: PSPad forum > English discussion forum > Re: Copy carriage return at line end.
Posted by: rajat | Date: 2005-04-28 19:25 | IP: IP Logged
Jan,
considering that only a small fraction or PSPad's huge userbase regularly check the forums, I think the general viewpoint is in favour of the option.
Jume,
for the keybd usage, nothing will change. shift+home or shift+end & copy will still not copy the CR... only the mouse usage is proposed to be changed (that too optionally).
Thanx all... more opinions are welcome.
Posted by: pspad | Date: 2005-05-07 20:39 | IP: IP Logged
OK. I will add option into [Special settings] - available with Dirrect edit button
GutterClickInclLF=1 mean if you click on left gutter, pspad select line include LF
Posted by: rajat | Date: 2005-05-07 21:01 | IP: IP Logged
wow thanx a lot!!
Posted by: dtmackenzie | Date: 2014-01-13 14:22 | IP: IP Logged
I couldn't find GutterClickInclLF=1 in [Special settings] - which section should it be in?
I'm using PSPad 4.5.7 (2450).
Thanks!
Posted by: pspad | Date: 2014-01-13 15:37 | IP: IP Logged
This option exists in the PSPad.INI file
Go to Program settings and press Direct edit button
You are in [Special settings] section
You should see GutterClickInclLF=0
You need to change it to GutterClickInclLF=1
