You are here: PSPad forum > English discussion forum > PHP/HTML/etc. beautifier / clean code / TiDy
Posted by: bkej | Date: 2014-03-07 10:04 | IP: IP Logged
I am looking for a tool inside PSPad in order to Tidy / Beautify / Re-indent automatically my PHP code.
Is there one inside PSPad ?
I found PHPStylist sourceforge.net but it needs a local PHP server that I don't have (using XAMMPP, or another, etc.)
I don't want to use a local PHP ! I just want to auto re-indent my code...
Where are the tools for that ?
PS : I never managed to use PSPad's Menu HTML > TiDy with PHP, but I think this is normal, because PHP is not HTML ;)
Best regards,
bkej
Edited 2 time(s). Last edit at 2014-03-07 10:11 by bkej.
Posted by: pspad | Date: 2014-03-07 11:29 | IP: IP Logged
You can use any external tool, add it in Settings / Highlighters external files or compiler
Posted by: bkej | Date: 2014-03-07 12:56 | IP: IP Logged
Thanks for answer.
Which tool would you recommand for beautifying (reindent, etc.) PHP files?
I don't know any, and Google gives me a lot of, so any recommandation would be useful
Any good PHP beautifier that I could use in PSPad?
Posted by: carbonize | Date: 2014-03-07 14:36 | IP: IP Logged
Carbonize
Posted by: bkej | Date: 2014-03-09 15:05 | IP: IP Logged
Doesn't this tool require a local PHP server?
(I wouldn't want this).
Posted by: carbonize | Date: 2014-03-10 09:07 | IP: IP Logged
Yes it does but have yet to come across a JavaScript alternative.
Carbonize
Posted by: Andreas | Date: 2014-03-10 15:53 | IP: IP Logged
Yes it does, but you don't have to run the server. Just install xampp with only the modules apache and php. Link to the php.exe in /xampp/php/
