You are here: PSPad forum > English discussion forum > File opens in HEX-mode
Posted by: tjokkis_ii | Date: 2012-08-16 08:30 | IP: IP Logged
I have some text(?) files that since version 4.5.6 always opens in HEX-mode. They opens and looks fine in notepad and other text editors, and was always treated as text in PSPad before I upgraded to 4.5.6.
Is there a way I can force PSPad to open files as text?
Posted by: pspad | Date: 2012-08-16 10:19 | IP: IP Logged
PSPad has reason if he open file in HEX mode. I guess your file contains some nonprinted chars from the begin of ASCII table.
You can switch off binnary file detection.
Go to Program settings / Direct edit button
Change variable of: AutodetectBinnary=0
Posted by: tjokkis_ii | Date: 2012-08-16 13:04 | IP: IP Logged
It was a handful of white spaces at the start of the file.
Changing the setting solved my problem, thanks a lot.
Can I comment out lines in "Direct edit"?
(I like to keep a copy of the original values, both to remember what I have edited manually and the default value.)
Posted by: pspad | Date: 2012-08-16 15:08 | IP: IP Logged
You can. But you can delete line - this will reset setting to it's original value.
