You are here: PSPad forum > English discussion forum > Mouse Wheel scroll Lines
Posted by: Mat | Date: 11/13/2004 14:45 | IP: IP Logged
Is the 'Mouse Wheel scroll Lines' option working? I have it set to 2, but my documents scroll 4 lines and my log window scrolls 10 lines.
Thanks,
Mat
Posted by: pspad | Date: 11/14/2004 18:09 | IP: IP Logged
It depends of how much scroll comand is send from mouse driver after one scroll wheel click.
Can somebody confirm MATs behaviour ?
Posted by: Mat | Date: 11/14/2004 21:06 | IP: IP Logged
I tried it on a different machine and with a different mouse and it was the same behaviour. Whatever value 'Mouse Wheel scroll Lines' is set to, the document scrolls twice that setting and the log window scrolls five times that setting.
Can someone else try this please?
Posted by: Stefan | Date: 11/14/2004 23:35 | IP: IP Logged
PSPad 2022, documents window, W2k SP3, simple DELL mouse, standard win driver:
set '2' Lines ---- will scrolls 4 lines
set '4' Lines ---- will scrolls 8 lines
set '10' Lines ---- will scrolls 20 lines
(BTW: would be nice to have an 'special setting' like "remember Settings-hive"
to have the same 'tab' as opened the settings-window the last time. (understand ???)
Will helps a lot for such testing issues, thanks)
greets, Stefan
(pleased user since 1722)
inofficial FAQs + Infos + Special Settings
Posted by: Mat | Date: 11/15/2004 01:32 | IP: IP Logged
Thanks for testing Stefan! If you have the time, does your log window scroll 5 x the amount it is set to?
I'm using 2021, Win XP Home SP 2 and a Packard Bell optical mouse.
Posted by: jgodfrey | Date: 11/15/2004 01:51 | IP: IP Logged
Build 2023 / 2.66 GHz Dell Laptop / WinXP Pro SP2 / Logitech Optical Mouse
Mouse Wheel Scroll set to "2".
Editor - Scrolls 4 lines
Log - Scrolls 10 lines
Search Results - Scrolls 1 line
Search in Files Results - Scrolls 1 line
FTP - Untested
Build 2023 / 3.0 GHz P4 Desktop / WinXP Pro SP2 / Microsoft Optical Mouse
Search Results - Scrolls 3 lines
Search in Files Results - Scrolls 3 lines
FTP - Untested
Something seems a bit inconsistent...
Jeff
Posted by: pspad | Date: 11/15/2004 21:05 | IP: IP Logged
> Settings-hive"
Its something else than seting in Program Settings / Files ?
[x]Save work/desktop
[x]Remeber file state
Posted by: pspad | Date: 11/15/2004 21:08 | IP: IP Logged
OK. It looks like LOG is 2 more tims scroled than Editor window.
This settings sets how many lines is scroled for one impulse from wheel. I can't change, if mouse sends 2 impulse per one wheel click.
standard Windows component, I have no influences. Lines are set in Mouse driver settings
Posted by: Stefan | Date: 11/15/2004 21:29 | IP: IP Logged
Sorry, i didnt found the right (english) words.
In the past i would say, "the TAB in Settings window",
how can i this time describe those entrys in the settings window ?
I mean
if i open "Program Settings / Files " for example
and close the settings windows
and than open the settings window again,
iam in the "Program Settings / laguage tab"
instead of "Program Settings / Files "
But it would be nice to have the same "tab" as bevor.
Maybe its not important for all users but for testers,
so i wanna suggest an new [special settings] entry
RememberSettingsTab=
less prio pls
THX
@Mat
I have no Log
But in SearchResult window i scroll 5 lines by setting 2 or 10 lines
But for me its no really matter, thought.
greets, Stefan
Posted by: pspad | Date: 11/15/2004 21:43 | IP: IP Logged
> window ?
I understand now. No problem to do it.
