You are here: PSPad forum > English discussion forum > [feat req] Block align by delimiter
#1 [feat req] Block align by delimiter
Posted by: Stefan | Date: 08/29/2004 20:17 | IP: IP Logged
Hi Jan,
i search for a feature and didn´t found the right one.
I have often CSV files or wordlists.
e.g. in such case:
berücksichtigen :: to bear in mind
durchführen :: to enforce
prozessieren :: to go to law
Haftung übernehmen :: to assume del credere liability
haltmachen [alt] :: to stop
handeln :: to trade
No i want the block vertikal align for nice print out (or do smtg with one column)
I tryed a RegEx s&r
search for ::
replace by \t\t\t\t::
but the effect is not so good.
Is it possible to implement a feature like
search for a delimiter and move it to pos xy at the same line
Dialog box example:
Block Align
  delimiters        [       ]
  move to pos.   [       ]
[ ] Select. [ ] Entry scope
silly code example:
- goto first line of selection/TOF
- store curent pos. of delimiter e.g. 12
- read wanted new pos. e.g. 30
- 30-12 =18
- (if result negative send error MsgBox)
- insert 18 blanks bevor delimiter
- If not end of selection /EOF GOTO next line
Works only for one block/delimiters after another.
The delimiters are   :   ,   ;   ::   blank   space   | or what else (good is if user can define herself).
greets, Stefan
image (pleased user since 1722)
inofficial FAQs + Infos + Special Settings
#2 Re: [feat req] Block align by delimiter
Posted by: Stefan | Date: 08/29/2004 20:34 | IP: IP Logged
Extra fine would be a table generation:
        CSV table generator
[x] Ad delimiters line[-] every [2] Line
[x] Ad | at front of each line
[x] Ad | at end of each line
[x] Ad | instead [::] delimiter
[ ] Ad [ ] extra blanks on longest line
[ ] Horizontal Align for each cell
to get
| test entry one | some another text |
|                      | in this cell             |
| First Line        |
| Second Line    |
| durchführen    | to enforce
| prozessieren   | to go to law
greets, Stefan
#3 Re: [feat req] Block align by delimiter
Posted by: gogogadgetscott | Date: 07/27/2005 21:14 | IP: IP Logged
Let me know how this works for you.
Const module_name = "Align"
Const module_ver = "1.00"
Sub AlignCol
text = handleSelText("")
Set regEx = New RegExp
delimiter = InputBox("Enter delimiter.", module_name, ",")
regEx.Pattern = "(.+)\s*" & delimiter & "\s*(.*)"
regEx.Global = TRUE
regEx.IgnoreCase = TRUE
Set Matches = regEx.Execute(text)
MaxLength = 0
For Each Match in Matches
length = len(Match.SubMatches(0))
If length > MaxLength Then
MaxLength = length
End If
Next
newtext = ""
Spaces = MaxLength - Len(Match.SubMatches(0)) + 1
newtext = newtext & Match.SubMatches(0) & delimiter & String(Spaces, " ") & Match.SubMatches(1)
Next
handleSelText newtext
End Sub
'// @param string Text to replace selected text
Private Function handleSelText(text)
On Error Resume Next
Set editor = newEditor()
editor.assignActiveEditor
If text = "" Then
'// Get selected text
handleSelText = editor.selText
If handleSelText = "" Then
'// No text was select. Get all text and select it.
handleSelText = editor.Text
editor.command "ecSelectAll"
End If
Else
'// Set selected text
editor.selText text
End If
End Function
Sub Init
menuName = "&" & module_name
addMenuItem "Align columns" , menuName, "AlignCol"
End Sub
#4 Re: [feat req] Block align by delimiter
Posted by: Stefan | Date: 07/28/2005 13:23 | IP: IP Logged
Woow thanks.
Here my tests.
First trim trailing spaces
I have
delimiter ::
i get
i have
Name, Tel/Fax extension, Bxl Building ,Bxl Office, Stb Building, Stb Office, Group
De Heer Ivo BELET, 623, Altiero Spinelli, 08F259, Louise Weiss, T09057, PPE-DE
Mevr. Frederika BREPOELS, 862, Altiero Spinelli, 08F266, Louise Weiss, T09055, PPE-DE
M. Antoine DUQUESNE 216 Altiero Spinelli 09G157 Winston Churchill M02080 ALDE
De Heer Saïd EL KHADRAOUI 564 Altiero Spinelli 12G103 Louise Weiss T07045 PSE
delimiter ,
i get
the lines without delimiter , are deletet from the script.
And the last column is separated only.
Anyway thanks.
This script could be handy some times grinning smiley
Maybe, if you want and have time,
you wanna improve your script to seperate multi columns as in a address list ?
I found some csv for testing:
www.mobiledb.com
www.memoware.com
