You are here: PSPad forum > České diskuzní fórum > Re: Kontrola poctu zavorek v batch souboru
Goto Page: Previous1 2 3 4 5 6 7 8 9 10 11 ...LastNext
Posted by: pspad | Date: 2015-06-04 11:38 | IP: IP Logged
Vsak taky jeste ten "dalsi" build nevysel. Prispevek jsem psal 31.5. a posledni build je z 24.5.
Posted by: lazna | Date: 2015-06-05 08:21 | IP: IP Logged
Aha
Posted by: lazna | Date: 2015-06-20 16:27 | IP: IP Logged
Tak zavorky jeste porad nefunguji spravne, napriklad zde jsou ignorovany docela:
if "%%e"=="SNR" if not "%%g"=="" (set snr=%%g) else (set snr=----)
Posted by: pspad | Date: 2015-06-22 06:09 | IP: IP Logged
Opraveno. Dostupne opet v dalsim buildu
Edited 1 time(s). Last edit at 2015-06-22 07:08 by pspad.
Posted by: lazna | Date: 2015-07-09 17:31 | IP: IP Logged
V teto konstrukci je posledni komentar (z me neznamych duvodu) zvyraznen svetle modrou barvou, oproti trem predchozim zvyraznenym tmavemodre.
REM == Vezmi vsechny customery kteri nejsou v historii a predepis jim prispevek.
for /f "tokens=1,2 delims=#" %%a in ('
sqlite3.exe -separator # "database\proton-test.db" "SELECT pid,fee FROM customers WHERE NOT status='4'"^;
') do (
REM == Divam se zda predpis pro dane obdobi uz neexistuje ===============
for /f %%A in ('
sqlite3.exe -separator # "database\proton-test.db" "SELECT EXISTS(SELECT pid FROM prescripts WHERE pid='90021' AND period='7-2015')"^;
') do (
REM == Pokud neexistuje, predepisuji ====================================
if not %%A equ 1 (
sqlite3.exe "database\proton-test.db" "INSERT INTO prescripts(pid,amount,period,timestamp) VALUES ('%%a','%%b','%month%-%year%','%ts%')";
REM == A pisu do logu... ================================================
if not "!errorlevel!"=="1" (
sqlite3.exe "database\proton-test.db" INSERT INTO logs^(type,timestamp,sys_user,content^) VALUES ^('12','%timestamp%','SYSTEM','Failed to insert prescription for PID %%a and period %month%-%year%.'^);
Posted by: pspad | Date: 2015-07-09 17:52 | IP: IP Logged
Ve verzi, do ktere uz mam zpracovanou posledni opravu je to v poradku.
Posted by: lazna | Date: 2015-08-24 18:43 | IP: IP Logged
for /f "tokens=8 delims==,%( " %a in (ahoj.txt) do something.exe
V teto konstrukci by procento nemelo byz zvyrazneno, jako parametr "delims" se jedna o obycejny znak, pouzity jako delimiter.
L.
Posted by: lazna | Date: 2015-08-24 18:55 | IP: IP Logged
Podle me to muzete vztahnout na vsechno mezi temi uvozovkami.
Posted by: pspad | Date: 2015-08-25 07:42 | IP: IP Logged
Opraveno
Posted by: lazna | Date: 2015-09-05 18:55 | IP: IP Logged
Pokud se nevola navesti ale jiny script (retezec za 'call' nezacina dvojteckou) pak napriklad zde:
call functions\show_data.cmd
je zvyrazneno slovo 'functions' ackoliv je to jen soucast cesty, a 'cmd' ackoliv je to jen pripona volaneho souboru.
'cmd' brat jako oznaceni samotneho shellu asi jen tehdy, pokud stoji na zacatku radky nebo pokud je pred nim (a za nim) mezera.
Pokud retezec za 'call' nezacina dvojteckou, pak se jedna o cestu k volanemu souboru. Cesta je vse do prvni mezery, vse co nasleduje dale jsou parametry volaneho scriptu. Pokud je v ceste k volanemu scriptu mezera, cesta musi byt cela cesta uzavrena do dvojitych uvozovek. Pokud je v parametru mezera, musi byt uzavren do dvojitych uvozovek.
